2014 RAM Question
mattgt
I just got a 14 ram express RCSB
I ORIGINALLY had a 2012 express RCSB
Would all the performanc parts bolt on the same
Example kn 63 series intake
Headers tb catch cans ... 2/4 drop beltech springs
Did anything change for the 14 modding wise?
Would i be able to just swap them from my 12
I seen on Moe's site that it ranges only 09-13 and was
Interested in a LSD and gear and some more mod
But would like to know if they will fit on a 14
Thanks
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Thanks
The cold air intakes and ported throttle body changed in 2013. The exhaust systems, headers, catch can, tuners, and coil spring drop kits are all the same. The rear limited slip unit is the same from 2011-up, but nobody makes an aftermarket unit for this, nor do they make aftermarket ring/pinion kits. If you are 4wd, then that front axle changed in 2012, and again, there is no aftermarket support for the 12+ front axle.
