2014 Sport 8 Sp lurches at start up, anyone else?
Coop427
In Sane
14 Ram 1500 Sport
I need your input. When I start the truck, twist the knob to D, I need to be standing on the brake pedal or it will chirp the tires and lurch forward. It only does this when I start out in the morning, not if I'm in and out running errands. Not sure if I may have a brake boost problem or a trans problem. Any input is greatly appreciated.
I'm at 4200 miles so I'm going to ask dealer at first oil change.
AzRamLover
I don't have it that bad but when the fluids are cold, I get a lurch putting her into drive. It certainly doesn't chirp the tires, though - I would get that checked out.
Kotta390
Cold morning starts my truck lurches forward too, but if you check your rpms they are also a bit higher as well until the engine starts to warm up. So take that into consideration.
cbsmith
New Brunswick, Canada
2014 Ram 1500 Outdoorsman
If you have 3.92 gears and the 8 speed it is a pretty low gear ratio in first gear. In the morning, especially if it is cool, the engine will idle at around 1500rpm for the first 30sec - 1 minute. If you put it in gear it will lurch forward pretty good if you are not completely standing on the brake, but I haven't had it chirp the tires though.
MyOhFive
HEMI
Are you one of those people that slams it in D about 0.023 seconds after turning the key? Give it 5-10 seconds after actually starting to let the RPM settle slightly. The first second or two after it starts cold in the morning, it can b cranking as much as 1200 rpm. So if you're dropping it in D right away you're basically smashing a trans that's at a dead stop into a rotating force going 1200 RPM.
And an 8spd 3.92 truck does not take a lot of force to chirp the tires. Hell the TC only flashes at about 1500.
clh1220
st Louis
Let it warm up more than 3 seconds and it won't do that. My wife does that to mine. She complains about that and I tell her don't turn the key and put it in drive at the same time.
Coop427
Coop427
In Sane
14 Ram 1500 Sport
Thanks for the replies. I usually let it sit at least 30 seconds, but I'll give it longer & see if that helps.
BlownGP
Houston/Baton Rouge
OMG!!!!!! My wife does that and bugs the **** outa me..lol
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
Cold start you are running about 1200 rpm. Until it idles down it is possible to get a lurch or clunk in the drive line.
That is a lot of torque to throw at a static drive line.
Fullmetal
Pennsylvania
I wait for the rpms to go below 1000 usually at ~500 before I put the truck into gear. I thinks this will solve things for you.
Dubstep Shep
Houston
2014 R/T
Just give it a second to get out of the start up phase before putting it in drive.
Awastatyme
Southeast Texas
2015 Ram 1500 Crew Cab Laramie
I normaly wait till my RPS get below 1000 before I put her in gear.
FXCLM5
2017 Laramie CC
ED 3.0 V6
****, i do quick starts takeoffs,
but i always put my truck in R, and i dont need the brake lol
guess i maybe turning on my truck and shifting too fast as well
Coop427
Coop427
In Sane
14 Ram 1500 Sport
Thanks, you guys nailed it. I used to let my truck warmup for at least 20 seconds but apparently it takes longer. I've been using the remote start lately & the lurching forward has gone away. Thanks.
jerryb
USA
Mine does it worse at cold starts. Bugs the crap outta me. She wants to run lol
14BlackRAM
5.7L
My girlfriend isn't allowed to drive my truck anymore cause she does that too. And then hammers it down the road because she's usually late. lol
Arturo Rojas
