2014 WIN replacement
moodyism
3.0 TD
Has anyone replaced the WIN module? If so where did you get it? How much? Was it hard? Can you reprogram with obd reader? Thanks
I have found a place in Texas that will repair it for $150. Doesn’t require new fobs or programming.
By WIN module
which unit are you referring to
The Ignition Switch
or the unit that is located behind the rear seat on the drivers side near the exhaust or pressure vent
or
the RF Hub Module, also called RAM 1500 Keyless Entry-Receiver Module for Key Fob Remote
Located by the drivers side Cabin Pressure Relief Vent on the rear wall of the cab
M
moodyism
3.0 TD
Sorry I didn’t know there was more than one. It’s for the ignition. Thanks
There is only 1 & it is the ignition
The other thing is sometimes confused with it
It is just a terminology mistake
Sort through these results
The new WIN Module likely won't come with new FOBs
Although one company does come complete with 2 FOBs & Win Module & they are programmed to work with each other
The Win Module is not programmed to work with the Ram, so that has to be done.
After you have everything that you need, make the change over where even you are going to get the Win Module programmed to the truck
Otherwise you might need to get towed
