avolnek
- Jan 5, 2015
- 266
- 96
- 2015 Ram 2500 CCLB
- 6.7
I am not going to argue about the difference in towing. Diesels have been out long enough that people expect a gas engine to lug fully loaded at 2000 rpm and that is just not going to happen. If you keep a gas engine in the proper rpm range it will pull and not hunt for gears but people are not comfortable with the rpm. It does not mean it is not capable it is just a different animal. Now admittedly I have no experience with hills and mountains. All we have down here is the I-10 bridge over the calcasieu river and it is like 6%. I have pulled plenty of heavy trailers over it and was able to keep up with traffic just fine. Granted it does not go on for miles and miles but anyone buying a truck should definately consider the terrain. The read ups on the Ike tunnel challenges are entertaining but it does not influence what truck I buy because I will never drive there.
I was referring directly to my personal experiences with the 6.4 Hemi. Flat towing on the interstate at 62 mph, manually locked into 4th gear with my 5th wheel the truck would cruise at ~2700 rpm which was acceptable in my book.
What the Hemi didn't have at that point was enough grunt to accelerate without first down shifting nor the torque to maintain that speed up any moderate hill. I seen 3rd gear jumping up to 3500 rpm and 2nd gear a number of times...
I am not ******* on the 6.4, i truly liked that motor! For a gas engine that thing was a power house and had i never towed with a diesel prior i'd certainly brag about it. But having towed with a diesel and now again towing with a diesel after trying a big block gasser I can honestly tell you it wont happen again...
Mileage, power, stability and resale all outweigh the only true negative of cost factor hands down in my opinion...
Have you looked at a year or two old diesels? they sell for what a new truck sells for virtually while the gas engines drop nearly 10 grand...
