2015 Ram 1500 lift
SunLee
NM
Hi!
I have a 2015 ram 1500 laramie, which is a air ride equipped model.
I want to lift it approximately 2.5 to 3.5 inches.
Can it be done with leveling blocks or specific lift kits?
And how much would it cost?
Thank you
S
SunLee
NM
@kurek
Thank you!
So, you mean, essentially, I need something like those kind of kits that you recommended, not just a simple set of blocks, right?
kurek
Northwest
There's not anywhere to stick blocks really... I think there's a way to trick the air suspension to stay in its higher mode which might get you what you want?
Some people have converted their air suspension over to coil springs and then used regular lift struts and lift coils to do ~2"-2.8" lifts but yeah other than that you need a full lift kit, there's no cheap way to do it.
S
SunLee
NM
@kurek
Gosh, I kinda wanna replace my tires to somehow larger a/t tires, not monster big tires tho, that's why I want to lift it.
Probably I might have to get just the same size or little larger ones.
Thanks anyway!
Mike83
Canada
Interesting products. Do both work well in all the settings including entry/exit?
Nicholas Lozano
