2015 ram 1500 Lifter failure… dreaded
Barr2255
Barr2255
California
Yeah, I plan on putting the old one back in to see if it remedies it. If it doesn’t I guess just replace the water pump and flush the radiator and cross my fingers lol
Always test a new thermostat before installing it,even that doesn't mean it'll still be good in a couple weeks,but at least you'll know it's good when you install it.
These days don't be surprised if your new thermostat goes south in a couple weeks or months,the days of them lasting 10 years are long gone. Boil your old thermostat before re-installing it,so it's clean going back in.
Barr2255
Barr2255
California
Will do, I’ll wait until the wife isn’t in the house so she doesn't get mad I’m using her exspensive pans! Lol
So I take it my temps are hotter than yours?
By a long shot,but then again my truck isn't really stock,lol. I run a 180 t-stat and dual remote oil filters to keep both coolant and oil temps down where i like them,lol. My truck stays under 200f,even when i have my foot buried through the firewall for 5 miles or more,or i'm making back to back passes at the track.Even my oil temps hardly ever get over 200f.The highest i've ever seen my oil temps was when i was playing with a built Suburu WRX in the mountains one time when it was 95F,and the truck was in 3rd and 4th running between 4500 and 6500 rpm for 20 miles staying ahead of the WRX,and i seen 210 on oil temp that one time.
Barr2255
Barr2255
California
Dual oil filters are keeping your oil temps down? Is that due to volume of oil? Seems strange. A lower T-stat temp does not decrease coolant temps. It opens sooner, to allow flow sooner. The cooling system “radiator and pump” dictate how much heat gets bled from the coolant. Theres formulas to calc how much heat gets bled from the coolant vs time spent in the radiator. The thermostat doesn’t dictate anything in regards to your actual “up to temp” temperatures. I’m not sure how your running those numbers but I know for a 100% fact a lower temp T-stat and dual oil filters isn’t dropping your temps that much! If that was the case me and all the other sprint car guys would be running dual oil filters and no thermostats lol
What mods do you have done to your truck?
Barr2255
Barr2255
California
I play with Suburu WRX’s in my Infiniti G37… my truck is a paper weight powered by a hampster wheel in comparison lol
Fun fact my G37 has never had a check engine light since I’ve owned it and it’s been beat on! I’m meticulous with maintenance but holy cow I was young when I first bought it and it’s seen 145+ mph on multiple occasions. Those days have slowed though since I’ve had kids. I keep my hooligan stunts on the dirt track with a wing and a 5 point harness. I did have a SC C6 vette for awhile. 600hp and 601 ft lbs torque on the dyno. It was a beast. Sold it after getting a bit squirrelly at 165+ on the back roads and wife was with me.
Last time on the dyno,my truck made 572 lb-ft at the tires at a lowly ole 3200 rpm,truck also plays with 717 horse Hellcats at the track,lol.I have a few buddies with KittyCats that won't line up beside it,as it's embarressing when a full size 5300 lb 4X4 beats them through the lights,lol.The truck was a bit of a sleeper ;)
Barr2255
Barr2255
California
So it’s not naturally aspirated. Sweet truck
Ken226
Washington State
I'm guessing your truck has the 8 speed? :33:
Barr2255
Barr2255
California
then Giggle gas? No bolt on’s are making that power. Thats almost 700hp to the crank if your at 572 to the wheels. Make a believer out of me? The TRX is 561 to the wheels.
You should post your build and whats done to that truck.
Barr2255
Barr2255
California
So hopefully to finish this thread on my rebuild and to circle back around to the cooling scenario.
I pulled the thermostat and boiled it along with the old one, they both opened the same amount at 203 degrees according to my digital instant meat thermometer.
Pulled the radiator and sure enough there was a lot of crap that came out of it when flushing with the hose. I must of disturbed a lot of crud when I did the rebuild. I went ahead and did a couple distilled water flushes after putting everything back to get the rest out and…
Fast forward it’s all back together with the new thermostat that I put in during rebuild and temp sits between 199 and 204 on the highway 75 degrees ambient temp. Put another 120 miles on it today round trip to my office. Now to go look at trading it in… haha JK
Ken226
Washington State
Awesome!
What was the crud that came out?
Barr2255
Barr2255
California
Awesome!
Looked like chunks of rusty sediment? maybe some old gasket material from cleaning the block? Maybe someone put some stop leak in to fix a busted radiator or something not sure.
Could be casting sand as FCA has issues with getting the blocks cleaned out after they're cast,it's more common in the 6.4's,but 5.7's have also been known to clog heater cores and rads with left over casting sand.
Barr2255
Barr2255
California
Can we get that last post removed mods? Don’t need that kind of stuff floating around these forums.
Griffin
Administrator Moderator
Yep. In the process of deleting the post. Member got hacked, so we have to go in and clear them all out. Thanks for reporting it
PVilefort
HOUSTON, TEXAS
3.6L V-6
It seems that the 5.7L and 6.4L Engines are having the same or similar problems that have been occurring with the 3.6L Pentastar V6. Oil selection isn't the problem but parts in the valve train including the camshafts have been failing since the newer engine design appeared in 2010. There is a class action lawsuit at this link: https://mycarvoice.com/news/hemi-problems-leads-to-class-action-lawsuit/
Even if you do not have problems your resale value is in the toilet.
  • RAM-STAR-Case-Lifter-and-Follower-Failures.pdf
Barr2255
Barr2255
California
Just wanted to give everyone an update, since most people don’t ever update after fixing a problem on their vehicle. I’ve put around another 8k on my truck since rebuilding. Truck is running flawlessly, lots of those miles are towing equipment trailers with weights from 3k lbs to 8500lbs. The camshaft pin hasn’t sheared off (WildOne) =) still at the 63’ ft lbs speced by the manual. I did do away with the shutters and put a 195* thermostat in it. Definitely helped with temp pulling grade with the trailer fully loaded. All in all the truck is doing well and in typical Ram/chrysler fashion falling apart around the motor. Let me know if any of you are on the Ford diesel forums…. Brand new 2025 F250 powerstroke sitting in the driveway to replace the old white buffalo… Lol hope yall are doing well and again thank you all for your opinions and willingness to help.
Arturo Rojas
