SwollenMonkey16
Is the 2016 2wd suspension the exact same as the 14s and 15s? I've found several spacer kits that even the manufacturer doesn't know if they work. I want 2.5" in front and 1.5" rear.
Also is everyone disconnecting the brake caliper? And if so do you have to bleed brakes after reinstall?
Awesome thanks man. And the only reason he had to undo a break line was bc his lift was bigger so he needed an extension correct?
