2016 Ram 2500 6.7l Transmission Problem?
dwall2181
Charleston, SC
6.7L Cummins
Hi guys,
I changed the transmission fluid on my 2016 Ram 2500 6.7l Cummins and noticed what looks like possible cracking in the valve body on the 68RFE trans.
How concerning are these cracks and what do you recommend?? (pictures attached)
I do have a bit of shudder in overdrive at very low RPM's that goes away as soon as I give it some pedal. No shudder otherwise. I run a 75hp tune and I thought that was the standard torque converter shudder you hear about with the 68RFE.
Thanks for any help.
D3EC5401-8682-443E-A71B-8B9D6D51533A_1_105_c.jpeg7B30ABA7-E425-4D4B-B196-851B26EFB800_1_105_c.jpeg06D26F07-C6A6-49F3-9877-1F59BB2DB2B1_1_105_c.jpeg8B4B30BC-A111-4AAC-868E-91E7BDDAC04D_1_105_c.jpeg
bigdodge
Those are not cracks. That's just some roughness from the casting process
mtnrider
Georgia
Casting marks, nothing to worry about. The shutter in OD is most likely your clutches slipping (going out). That 75hp tune is going to cost you a trans rebuild Real soon...
