bgray
Sold my 15 RT to get into a 16 sport CC 2wd. Have kid #2 on the way, and its time for a bit more wiggle room inside the cab.
Factory ordered a CCSB Flame Red loaded up Sport, none available locally(no one buys 2wd's around here). Dealer says it'll take 4-12 weeks, but said usually around 8-9 realistically to get them. Im past 4 weeks already.
As far as plans for the truck, im keeping it really simple, my last daily driver turned into a fully built truck, and im trying to avoid that with this one.
Parts Waiting
-Exterior
Shorty black antenna
LED bulbs for reverse, plate, and cargo lights
HID 5000k front kit
Body shop will shave the rams head on tailgate, paint handle, and antenna base red
I bought a Sport grille with mesh inserts, decided to shave the badge and rework the center bar so the lines flow like stock. My previous trucks have had similar work, custom touches but come across stock
-Stock
Modded Stock
WE removed the Center post on the bumper to make 1 big opening(rolled and molded edges) MAde a custom badless OEM grille, and the Hood is off a 01-02 HD Silverado thjat has been cut and molded to work on GMC headlights
-Wheels and Tires
305/35r25 Pirellis
24x10 Dub Swerv Rims - usually not a chrome wheel guy, but on red I think i can pull it off.
-Drivetrain
Corsa Exhaust
AEM Filter
Stock as stock can be. I was really impressed with how my 15 RT ran, so im hoping this truck will drive similar, if not i'll probably add a TB and a Tune to the Mix.
-Suspension
Was Never happy with my Belltech 964SP. Never dropped the truck enough to my liking, and when I cut the springs another Inch it drove like **** after. This time around for sake of better ride and aesthetics I ordered an Ridetech kit. Im not trying to lay frame by any means with this truck(i have another truck for that) just going for increased ride and adjust ability.
Front is the Shockwave setup
Rear is a Bag setup to replace stock coils. Ordered the adjustable rear shocks(fronts are adjustable already) so I can dial in rebound evenly
For air managment i went with the Airlift 3 p setup. 5 Gallon tank, and one 444C viair black compressor(might have to upgrade to 2, well see). Going to mount 3p and compressor under back seat by back wall, and tank inside frame.
Also ordered the Spohn Adjustable rear end kit. Had it on my RT, love how it tightened the rear end up and actually had a centered axle after lowering. Also have Hellwig front and Rear Bars and Hellwig adjustable rear end links
Think thats about it for now, as parts start showing up(alot of it is on order or sitting in boxes here) I'll post some pictures. Then ocne the truck arrives i'll start posting a ton with its progress
Parts Waiting
-Exterior
HID 5000k front kit
-Stock
Modded Stock
-Wheels and Tires
305/35r25 Pirellis
-Drivetrain
Corsa Exhaust
AEM Filter
-Suspension
