2017 1500 trans “clunking” noise HELP
JeremyFire
North TX
So my truck has just over 100k on it, I have owned since 36k. I did trans service at 68k, with factory pan and trans fluid. At about 89k I noticed a faint “clunking” sound when I get on the throttle from being off throttle. Essentially I am driving down the road, let off the throttle then when I get back on the throttle I hear the sound almost every time. Usually in higher gear. FYI, I am very light on the throttle. Now when I park in the garage (I just started using garage, wife is now an ex-wife) i here a fairly loud “clucking” sound from the trans when I first start the truck! I do park with my back left wheel on a chalk block bolted to the slab. This sound doesn’t happen everyday. I checked my u joints, no slack. No other shifting issues. So any ideas??
TheEnder
4.7L V8
What transmission do you have on your vehicle?
Sent from iPhone XS Max
ToxicFire
Canada
I was going to say u joint.
Sent from my SM-N960W using Tapatalk
J
JeremyFire
North TX
What confuses me is the sound when it starts up? It sounds like it is from the trans but it’s in park and the converter shouldn’t be ingaged and the u joints are not moving. I am at a loss
jws123
nj
Best bet is to try to record the sound and upload it.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
If the truck is RWD check the carrier bearing that splits the 2 piece driveshaft.
J
JeremyFire
North TX
Forgot to add, truck is 4wd. Going to try and get some audio and upload it. Thanks for the help everyone
J
JeremyFire
North TX
This url has the video I posted on YouTube. I am not 100% sure it is from a the trans, could just sound like it while in the garage. Any ideas will help
TheEnder
4.7L V8
Anybody have an idea on what it is?
Sorry for the late reply but this has been an issue on the 5th gen forums from what i’m seeing too.
If you’re shifting the engine into Reverse or Drive when this occurs, then yes, it’s normal. It’s backlash in the drivetrain, and when you put it into gear you’re moving a 50-70 pound tube of aluminum in one way or another, and it’s not going to stop on a dime etc in a truck.
J
JeremyFire
North TX
Thanks for all the help. This sound ONLY happens about 1-3 seconds after I start my truck. Never when shifting gears, driving, stopping, etc. any other me ideas on what it may be
Fatboy1989
