2017 Laramie
MAK
I am sure this question has been asked a hundred times. I have a 2017 stock Laramie. It has the factory 275 60 20 crap tires on it. I am planning to level it and put different tires on it. I don't want to go any wider because I live on gravel and really don't want to add flares. Can I go to a 275 65 20 tire without any issues. I read a lot about tires rubbing if you alter the tire size without changing your wheel offset.......
quietpeen
2021 TRX
Hellcat
Yes you will be able to run those on your stock wheels
lharrell79
That size will be fine with a level. The only drawback will be, the speedo will be off slightly, and your mpg's will suffer slightly.
