2017 Ram 1500 Lone Star - slight lurching/cluck after stop then accelerating.
JRDog
I have 2017 Ram 1500 5.7 Hemi 8 speed tranny, Lone Star Silver edition. After braking coming to a stop, and then letting off the brake to hit the accelerator there is thump and the truck feels as though it jumps forward a little. This happens every time I’m stopping and then throttling up the truck.
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Known issue with these trucks.
My 19 classic 1500 is just starting to do it at 9700 miles. My previous truck (17 1500) dealer replaced the driveshaft, on this one I am going to lube the driveshaft slipjoint under the boot and see how it goes.
RamCares
n/a
n/a
Sorry for the trouble @JRDog & @Ramm5.7. If at any point you decide to address this with your dealers, our team is just a private message away and more than happy to escalate a case on your behalf for further support.
Mark
RamCares
JRDog
JRDog
Thank you; that's nice to know you've got our backs
JRDog
JRDog
@Ramm5.7 - do you know if that drive shaft replacement was covered under power train warranty? Was there anything specific you or they pin pointed that if this is covered I might use when speaking to my dealer so it's quick and concise? When you say you're going to lube the driveshaft slip joint under the boot.. is that in the center of the drive shaft assembly or on the ends? My old 2007 Dodge RAM never had this issue so now I'm concerned of what might happen if this issue is left unattended?
Thank you.
Ramm5.7
So Cal
@JRDog, slipjoint on mine is in the center.
As far as dealer I had gone a couple of times for different things and kept pointing out the thunk. I guess finally it got some attention from a tech, like must of drove and felt it. Service writer called me and said they were swapping shafts so needed truck another day.
JRDog
JRDog
Thanks a ton. Great help/Guidance. I’ll speak to them and see how receptive they’re to check it out.
