2017 ram 1500 stock wheel well hieght
gaeta54
California
HI, I have a 2017 Ram 1500 regular cab 8 ft bed hemi 5.7 rwd. Does any one have this truck stock not loaded and can measure the front and back wheel well hieght?
Thanks for the help!
hunterdan
SE PA
2019 classic
I have some measurements written down on a paper in my truck. They measure from the bottom of the rim to the fender, not from the ground, so it should eliminate the tire size aspect of it. I'll post the numbers in the morning after I'm done work.
hunterdan
SE PA
2019 classic
The before numbers are bone stock on a 2019 classic big horn, standard ride height with 275/60r20. Measuring from the bottom of the wheel, not from the ground. So, going from the bottom of the wheel, pass the center of the hub and up to the fender. This should take out any difference from tire size or air pressure.
G
gaeta54
California
Thank you. Un loaded im at 29 in Front 34 in the back stock rims lt265/70R17
