2018 MDS
Punishher7
I haven’t seen any threads about disabling the MDS on the 2018s. Is it possible? Are guys even doing it anymore? I’d like do ditch the stock exhaust in favor of a louder setup however even the sound of MDS kicking on with the stock setup bothers me. If left alone I can handle the sound, but I’m fairly certain if I added an exhaust, it would drive me nuts.
AustinHarmon
Vancouver
2017 Big Horn
I have a 2017 1500 and what I do is just use the gear+/- and put it in 8th gear, and viola no more mds. Im sure it works with a column shifter as well. Also a tuner would take care of that. Unfortunately they want some serious $ considering we now have to replace the pcms to do so
Punishher7
Punishher7
If it makes any difference I have a power wagon w/ the 6.4L.
I’m familiar w/ the “8th gear trick” from my days w/ my 2014 1500 but I’m far too lazy to push extra buttons every time I jump in. I appreciate the feedback though.
AustinHarmon
Vancouver
2017 Big Horn
No problem! I think the only way then would be a tuner
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
You shouldn’t have an issue. The only time MDS even kicks on in the PW is at an almost completely closed throttle, and the engine sound is too low to really notice it. I had the same concerns you do, and I went with the Mufflex muffler delete. Zero regrets, and like I said the only time I can even barely hear the MDS is when I’m completely off the throttle.
MADDOG
Living in a Firepit
6.4L HEMI
Why is this in the 3rd gen section?
Moved to 4th Gen.
Back to the OP's question, the 2018 PCM encryption hadn't been broken yet last time I checked so removing MDS from the PCM is not doable...yet. Using manual mode on the transmission is the option available at this point.
Ramtruck16
Blue Springs Mo
Or you can leave your gas cap loose and the check engine light will come on and disable the mds, mine was like this for a while until i figured out the gas cap was causing problems
appzattak
Jerome, Idaho
I have a 2017, with a DS T2 and unlocked PCM. So far I have not been able to disable MDS through the tune. It let me choose the option to turn it off, completes the tune but does not disable it at all. I hoping that is just because I'm using the canned DS tune as I'm awaiting my Jay Greene Tune.
Sent from my iPad using Tapatalk Pro
Jbaker33
Cadillac, MI
5.7l hemi
I found this out the other day, the check engine light disabling MDS.
Do they have MDS on the 6.4? I thought it was only on the 5.7s? Maybe that's just with the older trucks?
whetrick1
I know I disabled mine with the custom tune. I think that's the only way.
RAYDEL PORTO
Miami
I have a 18 pw and i just hit the + on the shifter until it hits 6 and leave it there. The tranny will still shift by itself all the way till 6th gear and it wont turn on the mds or eco. But of course once you shut off the engine and start it well it goes back to normal
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
It takes two seconds to put the gear selector in manual mode. For around town I set it in 5. Then when you are getting on the highway turn back on MDS, set cruise, and you will get at least decent MPG for a 8000 pound barge on wheels.
