2018 quadcab 1500 back up leds?
matlocc
6cyl
New truck and the back up lights are too dim. Any suggestions for plug and play LED that is bright?
I do not want to deal with the resistors, but will if I have too.
Also want to replace the bed lights to bright led too.
1999 White C5 Coupe
GM has issued TSB’s regarding the use of LED bulbs in the back up lamps. They can cause a problem with battery drain.
I know GM is not Ram, but you may have problems with LED bulbs and no resistors added.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
I got my backup lights from Amazon. They did not need resistors. They were plug and play.
LUYED 2 X 1700 Lumens Extremely Bright 7443 4014 102-EX Chipsets 7440 7441 7443 7444 992 LED Bulbs with Projector for Backup Reverse Lights, White(Brightest LED in market) https://a.co/d/866Vo6f
Badger 13
North Idaho
2013 Dodge Ram 1500
There are plenty out there that work fine. If you don't feel comfortable with Amazon, you can check with sponsors here, or look at Headlight Revolution.
16WhiteQC
Hudson valley, NY
crazykid1994
I have lasfit bulbs in parts of my truck and other bulbs from headlight revolutions. Can’t remember which is in my reverse lights but they are 3-4x brighter than the stock filament bulbs
