2019 2500 Column Shifter Loose
Dalton
NE Ohio
6.7 TD
Took my truck in for a couple of service/warranty item. The shift lever was so loose I thought it was going to fall out of the column and a couple of times the truck was stuck in park. Turns out there is a service bulletin tsb-9004152 on this.
Parts are on order/. It is about a 2hr fix once they come in.
Rken1288
It’s a two minute fix. Pop off the rubber boot and tighten the bolt at the base of the shifter. I think there are a few YouTube vids on it. Easy fix
Rken1288
I think you have a typo in your title.
If there’s really a column shifter available for a 2019 I would buy it. Unfortunately we got the dial. :(
Diesel trucks have column shift.
Rken1288
Rken1288
True, and I don’t want to take this topic into the weeds any further. My response was based on the OP’s description of his vehicle as a 2012 gas truck under his avatar. GIGO.
I’m operating off my phone so I didn’t see his avatar. All good!
Dalton
Dalton
NE Ohio
6.7 TD
2500 TDs have column shifters. I need to update my profile.
glsander
