superjoe83
No, just heatedIs this glass auto dim?
Nice!Got mine wired up to my repined 2019 mirrors
Hi bud I was just wondering what you did with the repin on the blind spot mirrors with regards to the return wire for the blind spot lampSo I purchased a couple of sets of mirrors with blind spot. It turns out for sure the 2019 1500 mirrors do not fit. I did however purchase a set from a 2019 2500 with blind spot, camera, power fold etc. Does any one know the pin configuration on the 2019 tow mirror models so I can attempt to rein to fit my 2018 ram 2500 laramie? I tried to figure it out using the pigtail website, but was a little confused. Hopefully I can get that working along with the 360 camera and outer tow mirror to be adjusted electronically.
Nice. Can you let us know how you repin the wires? ThanksGot mine wired up to my repined 2019 mirrors
You have to enable four things in the BCM,I’m staring to think I need to disable or turn on some option in the config
I wired temporary leds and still got the same error and solid light still just like the Mirrors led .
If I can connect to the modules I would think the tail light side is good ?
What year is your truck? My 2015 has the same errors. I have sensors out of a 2016 GC coming next week to test out.I’m staring to think I need to disable or turn on some option in the config
I can connect to each module using the charger profile .
It shows .ecu mismatch on both BSM.
I also seen a canbus poor performance code .
The guys who have this working can you see if you are getting the ecu mismatch under the charger profile if possible .
Everything else works power food ,turn signal ,puddle lights and heaters .
Ok, now this is getting weird. Skuppy’s got a 2018, and he’s got the same behavior as you did- with everything hooked up, the blind spot indicators remain lit with the temporary unavailable message. We do have two confirmed successful 2018 installs here so far.What year is your truck? My 2015 has the same errors. I have sensors out of a 2016 GC coming next week to test out.
Sent from my SM-G965U using Tapatalk
I have those turned on .You have to enable four things in the BCM,
Doors- blindspot mirror present
Custsetmenu- blindspot alert CSM
Cabin net- RBSM right blind spot module
Cabin net- LBSM left blind spot module
I know I’m scratching my head here .Like what would cause a ecu mismatch would be program missing on a point in the bcm ?Ok, now this is getting weird. Skuppy’s got a 2018, and he’s got the same behavior as you did- with everything hooked up, the blind spot indicators remain lit with the temporary unavailable message. We do have two confirmed successful 2018 installs here so far.
Are you able to list a copy of your bcm details ?You have to enable four things in the BCM,
I will send you my sizes for a crew cab tomorrow. You'll need to subtract a couple of inches.Any idea how long to make the harness for a quad cab? I'll get some wire this week and start building mine so I can test too.
Didn't plan on doing it right away but want to make sure I don't have any weird issues too.
Sent from my Pixel 3 XL using Tapatalk
Thanks!I will send you my sizes for a crew cab tomorrow. You'll need to subtract a couple of inches.
Both your taillights were brand new, right? Do you know if the other confirmed install had new or used lights? I've been told that the VIN mismatch between current and original can cause issues in some cases. My left light is new and the right is used. I am going to try a VIN reset procedure to see if that gets the VINs to match and whether that clears the error. I'm not holding my breath on that being my issue though.Ok, now this is getting weird. Skuppy’s got a 2018, and he’s got the same behavior as you did- with everything hooked up, the blind spot indicators remain lit with the temporary unavailable message. We do have two confirmed successful 2018 installs here so far.
Mine are both used. One is from a wrecked truck, the other is from a brand new truck that we’re takeoffs for a utility bed swap. They both show the original VIN as being from their respective trucks, and my VIN as the current.Both your taillights were brand new, right? Do you know if the other confirmed install had new or used lights? I've been told that the VIN mismatch between current and original can cause issues in some cases. My left light is new and the right is used. I am going to try a VIN reset procedure to see if that gets the VINs to match and whether that clears the error. I'm not holding my breath on that being my issue though.
