2019 Limited center console
RAM-1500
Virginia
I have the center console tray that slides with cup holder and extra small storage. The main question is, How do I remove it? The problem is, there is a coin, a ball, or something that rolls around as the truck is moving. Annoying as heck. My goal is to remove whatever is rolling around in there. Anyone have this problem. The thing is the tray is like a bowl in a bowl. I have no clue how to remove it without breaking something. Your thoughts and help would be appreciated. Thanks
JD Martin
Southeast
I looked through the owner's manual and it doesn't tell you in there how to take it out. I am guessing you'll need the appropriate part of the service manual to figure that out.
Pudge
Alberta, Canada
2021 Power Wagon 75th
If you have something loose inside, it’s a dealer warranty fix.
Funroadahead
Minnesota
So it's loose in tbgg e lower compartment, but winds up near the middle so you can't reach it no matter where the upper part is?
I had this happen with a bottle of water.
If you move the armrest all the way forward, molded into the rear bottom of the lower compartment is a flip up stop that will keep whatever it is from going so far back you can"t reach it.
Rapid deceleration should then bring whatever it is right to the front.
skillzzs
SLC, UT
Cummins 6.7
There are 6 white plastic clips under the bottom of the console. Pushing up towards the roof of the vehicle on these clips will release the upper console from the base console and allow you access to the coins rolling around.
kbrown
5.7L HEMI
Sent from my SM-N950U using Tapatalk
VETTE277
USA
V6
Anyone have any additional comments about how to remove the entire sliding tray console compartment ? I'm trying to swap it for a limited one with the cupholder covers. Can't figure this out..
