2021 Cummins - New Fuel Pump?
JFV1134
Billings, MT
6.7 HO Cummins
Saw a couple articles and heard a few rumors that the Cummins engine for 2021 in the HD pickups will have a new high pressure fuel pump. Does anyone have any additional info? The articles stated that the "new" HPFP looks pretty close to the old tried-and-true CP3. My order on a 2021 3500 has reached KZ status, so I am definitely concerned about the CP4 pump. Seeing that they may have changed it makes me very content again!
Here are two links I am referencing:
https://www.hdrams.com/ram-moves-away-from-the-cp4-2-injection-pump-for-2021/
https://www.allpar.com/threads/2021-ram-hd-trucks-using-bosch-cp3-injection-system.236262/
Rick Ram-jet
Big Bear Lake Ca
2016 2500 4x4 CC / LB
6.4 L
Dose anyone know what the beginning build date is for the switch over to the cp3 pump on the 2021 model ram/ho cummins?
OR, is there a way to tell the difference between the cp4 & cp3 by looking under the hood?
Thanks in advance...
Rick Ram-jet
Big Bear Lake Ca
6.4 L
Did some research, here is what I found: the cp4 has a bit of a v shape and the cp3 has a non-discript shape with a finned cover on the back/rear!
Personally, I`ll be looking at the cp3/2021 model when it`s time to buy!
chri5k
USA
Diesel
Not really a "new" HP fuel pump. It is the old reliable CP3.
Orlando70
St Louis, MO
6.7L Diesel
I anyone does a swap from a CP4 to a "new" CP3 could you tell us how much $$$ it is. Ball park firgures more than OK
