2021 Powerwagon Suspension
pjcodner
Burnsville MN
Does anyone know if the springs, shocks and trackbar from a 2021 Powerwagon fit a 2015 Ram 2500 tradesman? The guy listing them say it fits 2017-2021 and I didn’t think there was any difference between a 2015-2017.
Thanks in advance
Paul
62Blazer
Midwest
I know aftermarket companies like Thuren Fabrication list the same parts for 2014 - 2023 Ram 2500 trucks.
olyelr
Kewadin MI
Yes they should fit no prob down to ‘14. The ‘19 and up front springs were a little taller then the ‘14-‘18, but they should still fit right in. Probly gain a solid 2” or a smidge more up front.
Nick@GotExhaust
Supporting Vendor
SC
Exactly. They will fit but will make the truck a good bit taller.
pjcodner
pjcodner
Burnsville MN
I am looking to accomplish two things. A bit of a lift to run 35’s on factory 20’s and to soften up the ride some. I don’t haul heavy loads but would add bags if I started to.
Thanks everyone for the replies. I will talk to seller to see if they are firm on the price. Not sure if $500 for springs, 4 bilstein’s, trackbar and rear sway bar links is a good price. They were pulled from a 2021 Powerwagon at 19k miles.
62Blazer
Midwest
I guess for comparison the cheapest leveling kit from Thuren is $980 that includes front springs, trackbar, and front shocks only. It's over $200 for the cheapest rear shocks.
I think the Power Wagon setup would be a nice option for your truck. $500 is probably not a bad deal, but not really a killer deal either. In the Jeep world it's common to put the Rubicon suspension on a Sport model for the same reasons (small lift and slightly better shocks, etc...) with the complete setup going for $200-$300. Actually just did this for a guy recently....but will say that Jeep Rubicons are way more common than Power Wagons. I would probably offer the guy $300 cash and see what he says. Not sure what the market for this stuff is as you don't see it very often.
pjcodner
pjcodner
Burnsville MN
Offered him $300 and will be picking up the parts on Saturday. One last question I know the Powerwagons have sway bar disconnects. Are the links longer than a stock 2500? If I need to replace mine what should I go with?
buckeyexx
Ohio
2016 Power Wagon
Hopefully I'm answering this correctly and if not someone can correct it but I wouldn't think the links would need to be any longer or be a problem. I say this because you can level your truck using a puck above the spring and get 2in of lift from it and the longer links are not needed so I don't see why it would be any different using power wagon springs.
pjcodner
pjcodner
Burnsville MN
Yeah that is what I am thinking as well however he did give me the rear links and I know the fronts have disconnects so that is probably why I didn't get those. He replaced everything with a full Thuren setup and they came with rear links.
buckeyexx
Ohio
2016 Power Wagon
The rear will be longer but the front should be the same. When I had my tradesman 2500 I did the front level puck and didn't need longer front links. I just did the thuren front springs and fox shocks this time on my wagon. And now have the stock springs and shocks I need to get rid of. You should notice a nicer ride with even going to stock power wagon suspension over a standard 2500.
pjcodner
pjcodner
Burnsville MN
Got the suspension parts on a few weeks ago. Took about 8 hours in my garage with jack stands and a pump jack. Worse part of the whole install was I didn't have big enough sockets to swap out the front track bar so I had to find a 27mm socket at home depot. I really like the ride of the truck now. It no longer feels out of control going over train tracks and bumps at 30-40 mph. The ride is a whole lot smoother. It doesn't even look too bad with the factory 20"s and stock tires. I thought for sure I would be buying new rubber after the swap but I think I will wait till these wear out.
olyelr
Kewadin MI
No pics?! :D
pjcodner
pjcodner
Burnsville MN
No pics?! :D
Here you go. I took them in the garage as it is raining out and the truck is fairly clean. :) That other tire in the first picture is my wifes Jeep Rubicon 392. Two 6.4l hemi's in the garage, does it get any better than that?
