2021 safe in center console key replacement
dakotanut
Needville, Texas
Just got this 2021 1500 Laramie. It has a safe in the center console but no key. Where do I get the key for this? I'd like to use it. Thanks.
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, 3.21 rear, 8-speed
+1 for locksmith. I have a small safe at home, thought I had lost the keys.
I did eventually find where I hid them, however...
Having purchased the safe and knew where I bought it and had everything I needed to reach out to the manufacturer to ask about a new set of keys, they were happy
to help me out, PROVIDED, I could supply the model#, the serial#, the key number (which is stamped on the keys I could not find), AND the original sales receipt.
As the safe was several years old and I knew I no longer had the receipt and couldn't provide the key number, I gave up.
It was just good fortune that I found the keys a couple days later. As you now own the truck I would be calling around. I have personally found a very large range of pricing on local locksmith services.
Good luck.
ric221
I 2nd the locksmith
roguerob
Tennessee
It’s probably a console vault. You can drill it out and order another lockset for it. I have one in my vehicle.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
This isn't a RAM item? Stealership installed item?
Pretty sure only the Built to Serve models came with the factory console vault. If your truck is a Built to Serve model then it was installed at the factory. Yours looks to be a Laramie so it's almost certain to have been installed by a previous owner.
dakotanut
dakotanut
Needville, Texas
So locksmith then? I don't know what built to serve is. Can you let me know please? Ty.
Kapone
We're you able to find a replacement key? Im in the same predicament. I bought used & now im looking for a replacement key. This is a factory installed Mopar lockbox.
markabby
Monticello, Kentucky
2020 Limited
isn't that for a gun? as the others said go to a locksmith. Drilling it out might work, but you can do more damage making it useless.
