2022 REBEL WON'T START
JazHandz
Ontario
We have a 2022 Rebel. 97k km on it. Bought it in 2023, had no issues until the last 6 months.
Randomly will not start. Won't take boost. So we get it towed. Use the orange strap to put in neutral to get it on tow truck. They take it to dealership, starts no issue. No error codes. No stored code. Whatever happens between it not starting, getting it in park to tow, resolves issue. This has happened 3 times at dealership and we get sent home with the truck. Cannot do anything to fix what they think issue may be because there are no codes, which is needed for the warranty work. These codes (not on purpose) have been weaponized and we cannot get any resolution. Last week, it did not start. I got it into neutral myself, rolled it back in driveway a little bit. Got is back in park and it started. Campbellford Chrysler has been amazing. They have kept it all week trying to replicate the issue, with no success. It has started every time. Seems to be a communication issue. The truck is in park, it just does not now it is in park it seems. Anyone has any thoughts?
***update***
Dodge dealership had the truck for a week trying to replicate the issues with no success. So I guess we are left with a truck that we paid 60k for, that we cross our fingers EVERYTME we need to start it. It has really changed things for us. We are avid campers and go places that tow trucks will not come to. We can no longer do that for obvious safety reasons. Really no point having it any more I suppose if no one can fix it
Army
First say the engine, so you have the Cummins my guess.
Now what symptoms do you have on the dash, is everything lit on the dash when this happens?
I'd take phone video of this everytime you start truck until it happens again, then you have proof.
Army
Is your fob close to your start/stop button what this happens? Have you ever put the fob close to ignition?
Why did you bring up boost excuse my ignorance.
RamDiver
Marlborough, Ontario Canada
2021 DS
You remember those old-fashioned jumpers to connect the battery to a donor vehicle battery for starting?
J
JazHandz
Ontario
The fob is close. It is in vehicle. The techs tried the fob in front of ignition. Brought up boost, as one of the tow truck drivers said he could not boost it to start it. Everything works in the truck except for it starting
RamDiver
2021 DS
Welcome to Ram Forum.
We will need more explicit details of this no-start condition.
Please update your avatar to show the 5.7 Hemi; this saves time for everyone.
Do you have an ignition key or a start button?
All the dash lights are normal, you mentioned.
Any clicks or noises when attempting to start?
Can you hear the fuel pump running?
BTW, most of us have ditched the practice of using jumper cables. I would choose to avoid them unless there's no other choice when off-road or I'm stranded in a very remote location.
Jumper packs are far safer for the electronics and potentially our pocketbooks. :cool:
Army
Guy used old slang for booster cables not what boost is, anyhow thanks for explanation.
The tech could not duplicate, my question is did you put the key fob next to start button and had this happen again? Should change fob battery anyhow, was that done?
J
JazHandz
Ontario
Yes, put key fob in front of ignition. Truck did not start. Battery on fob was changed
Army
ok that was the easiest thing.
Now, you want to test the voltage from battery to starter. You will want to do it while it is working, this will help you when it isn't. If you starter isn't getting 12 volts at that moment, the issue is between battery and starter or rf hub. If the starter is getting 12 volts, it is your starter. The reason there is no codes the truck doesn't recognize this fault, same things happen with ignition. OBD is more helpful with the stuff less easy to figure out, this is easy just have to do it. You dealer would know right away if it happened while they were there.
J
JazHandz
Ontario
Starter was replaced 3 months ago as they thought that was the issue
