2022 Warlock V6 - Is it dual exhaust or single?
Giorgio_Rampa
Vaudreuil
V6 3.6L
Those that have the 3.6L V6, does the truck come with dual or single exhaust?
Thanks!
14 Lonestar
The V6 comes with single exhaust, being that the Warlock is the 4th gen or Classic you can install the exhaust from the Hemi as long as it comes from a 4th gen.
When you ask if it's a single or dual exhaust, all the Gen4 DS body trucks are a single exhaust up to the muffler. Then depending on body/trim level will the truck have either dual out the rear or single. exhaust.
This probably holds true for the Gen5 DT body trucks also, only the TRX may have a true dual exhaust from the engine.
If you want to add the dual tips to your Warlock, you just need from the muffler back, the hanger points are there
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
What else is required to do the swap to dual tips? The rear bumper has to be swapped as well?
Thanks again!
14 Lonestar
You really do not need to replace the bumper, it is up to you. If you decide to keep your current bumper just angle the tips down. You will need an additional hanger and 2 rubber isolators.
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
The additional hanger and 2 rubber isolators are needed if I keep the current bumper or they're needed for the new bumper?
If I do decide to do this, I'll be swapping the bumper out.
Giorgio_Rampa
Giorgio_Rampa
Vaudreuil
V6 3.6L
Does anyone know if this is missing anything to do the conversion?
It's from a 2021 RAM Rebel
Nicholas Lozano
