Dean2
- Jun 17, 2021
- 4,444
- 8,890
- Location
- Near Edmonton
- 2021 2500
- 6.4
You can also reduce the number of regens by using the gear limiter and running higher RPMs, you don't need to get up to 70 mph to clear the filter. The older Cummins produced max torque at 1500 rpm, had 6 speed auto or manual transmission. The current version produces max torque at 1800 rpm. Most of the time they are loafing along at 1200 rpm when being daily driven with no load.
The issue with modern diesels that aren't being worked, is they are basically being lugged and not run at the top of their torque band enough because of the prevalence of automatic transmissions. This causes more soot to start with and does not get the exhaust hot enough to clear. If you use your gear limiter to run the engine at 1800 to 2400, max HP is at 2800 rpm, you will get way less regens. The cleaners are just a bandaide for not running the diesel in the correct rev ranges.
