heckcat9
Is there a better tool for holding the rear upper shock nut in place or will a 21mm crowfoot suffice? None of my 21mm anythings fit back there.
Also are these tabbed/bracketed, or whatever they are, nuts fairly durable?
www.thurenfabrication.com
2009-2018 RAM 1500 SHOCK NUT SET
The OEM RAM 1500 rear upper shock mounting nuts are hard to access. You'll often have to cut down a wrench to make it shorter to even fit in the space available. This kit gives you a custom wrench for removing the OEM nuts, and 2 new nuts with pressure fit tabs to make the next service much easier!
