22 1500 Laramie - AC not blowing hard
ryan421
AC is only blowing around 1/2 capacity when on high. I can hear the motor changing speeds for each setting. Changed the cabin air filter and looked at the blower motor. No visible signs of blockage and the blower motor seems to be in good shape.
Any help with this is appreciated.
CDN HO
Ontario & South Texas
6.7 diesel
I noted some after market cabin filters really restrict the airflow. As mentioned above, try it without the filter to determine if a filter or door issue.
markabby
Monticello, Kentucky
2020 Limited
true that! i bought one with charcoal in it...damn thing really restricted air....removed it and put a normal one in. big difference.
R
ryan421
Installed a new filter straight from the dealership. Air flow is better but still not a max capacity.
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
Stupid question installed for proper air flow direction?
Also check cowling under hood see if restricted
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
You could also have a partially clogged EVAP Core (A/C) or heater core inside the plenum box causing the issue.
More of an issue with older vehicles unless you're in a dusty climate/area.
Could also be a stuck/damaged mode door and/or motor.
utley
st louis
HEMI 5.7
I replaced my cabin air filter earlier this week with a K&N filter and my air flow doubled. Mostly because it was clogged AF, but I also only had 28k on the odometer so take what you want from that. Worked very well!
Burla
Army
2010 Hemi Reg Cab 4x4
I rip a hole in every cabin filter in every car I have. Mind you the air is generally clean anyhow, plus acts like a bypass, I rip a hole in one corner just to give a source of uninstructed air. That's what I do, who knows if it is a good idea, but air restriction killed my blower motor and that will happen once w/o me trying something. Remember when we had AC and no cabin filters? Been doing this for ten years :)
jimn
