'22 Eco acceleration shudder
KC Kevin
Mission Viejo CA
I'm at 8500-ish miles and have had an issue pop up. the acceleration just seems to drop off momentarily then resumes as if nothing happened. It's occurred on the last few drives; all on the same fuel tank. I didn't notice it at all prior to this fill up. It can vary from 'wow, what was that?' to barely noticeable. There is no apparent relation to engine temp and no warning lights come on.
Bad fuel maybe? Any thoughts?
KC Kevin
KC Kevin
Mission Viejo CA
Follow up- This issue got progressively worse. The truck finally stalled out last Friday. Initially it would not re-start. Second attempt it did. Then the engine light came on. Ram Connect shows a power train issue.
Soonest I could get it in was 5/19, 5 days after a call. And that was the best available from three local dealerships. They told me they needed 5 days to diagnose the problem.
Wow. I am not feeling good at all about this.
Paladin308
Wisconsin
3.0 Diesel
Following this because I take delivery on my 2022 Ram 3.0 Diesel. Please keep us informed
KC Kevin
KC Kevin
Mission Viejo CA
They couldn't locate the problem, Jim. When they restarted the engine at the dealer, the engine light was off. I am pretty annoyed actually, because the truck was in the shop over a week.
In driving it since, (over 300 miles) I have had one minor irregularity. Honestly, my guess is I got some bad fuel.
Mattatto
USA
3.0 Ecodiesel
Do you use any fuel additive live Hot Shots? Has this cleared up completely?
huntergreen
Marine Corps Navy Badge
Even though the engine light was off, a code is stored. They should be able to tell you what code was found.
KC Kevin
KC Kevin
Mission Viejo CA
I do not.
And it has in fact cleared up completely.
I am over 10,000 miles now and I love this truck! I am glad the problem was as simple as bad fuel. Once I burned through that tank and refilled, it hasn't resurfaced.
KC Kevin
KC Kevin
Mission Viejo CA
It's doing it again- acceleration starts jerking, and then the truck stalls. Engine light comes on and then off again. It's stalled in the middle of an intersection twice in the past week. Flashing 'Service Throttle Control' briefly at the time of stall. Seems to happen fairly close to the house which could be identified as a cold-engine symptom (although it's far from cold these days)
Back to the shop. Last time they wiffed on finding anything.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
go to your Local auto parts store
ask them to hook up their scan tool, so that they can read the CODE
Write the Code down, do NOT Clear it.
With that code in your pocket, go ahead & do what ever plan that you have.
If you choose to go to the dealership for another attempt to fix it.
Do NOT mention the code. keep it to yourself for now.
They have better equipment & should find it themselves.
Good Luck
Pickup a copy of the California Lemon Law, just in case
KC Kevin
KC Kevin
Mission Viejo CA
Ok, so the truck has now been in, and out of the shop for a 2nd time for the same issue. The dealership seemed to be WAY more interested in fixing it this time and not only did so but fixed it FAST. I dropped it over at 10:30am yesterday and it was ready at 7:30 am today.
They ended up replacing injectors 4, 5 and 6 and also replaced the fuel lines servicing the injectors. The code on the Repair statement was P062E, for those that follow.
My suspicion is that there was new information in the system (this time) about the problem and the needed repair.
Does it seem WAY to premature for injectors to be failing? I just hit 12,000 miles. The truck is 8 months old for gosh sakes.
GTyankee
3.0 ecodiesel
I have learned, that as long as the factory warranty pays for the issue
you can't complain to much, although some times being without that vehicle can hurt. In my case, my Ram is my only vehicle & it is also my way of making money. The dealership does not have loaners or even courtesy rides to & from the dealership.
If the dealer can't fix the issue, then during 36 month, 36,000 mile period, that is when the Lemon Law comes into play.
I bought an Extended Warranty, the day i drove the Ram home
I forgot about price shopping for the Mopar Plan.
Anyway, i have not paid for any work done on my 2016 Ram, but i have had 5 or 6 Recalls done since January 2016.
My 2009 Ram had a few issues, but my Extended warranty on it covered the higher cost issues, the rear differential went bad, but that was the dealers fault & they took care of it
It is on the short side for them to go bad, the other side of the coin very few injector problems have been reported with the EcoDiesel. Probably just a fluke that you needed injectors to be replaced and hopefully your problem is solved. If the problem happens again and the dealership throws more injectors at it, find a different dealership, they're throwing parts at it.
06 Dodge
Forest Grove, Oregon/soon Osage Iowa
6.7L CTD
Being they just announced the recall for the CP4 pump wonder if the pump is starting to fall apart an pushing metal shavings into the injectors, I also hope they replaced your fuel filters just to be safe... Hope your all fixed up and have no more problems...
KC Kevin
KC Kevin
Mission Viejo CA
They didn't change the fuel filter. From what I read, the CP4 pump recall is 2014-2020 model years.
DB Cooper
Califor
5.7 ETORQ
If the codes cleared after a day or so, I had the same issue... occurs from dead stop. It turned out to be a software recall related to the sensor on the active on/off at the start. Try disabling that until you get the software update.
As of now the recall is only for the DS body trucks even though DT body trucks use the same fuel pump.
The failure rate for the EcoDiesel CP4.2 bases HPFP is under 1%
KC Kevin
KC Kevin
Mission Viejo CA
My EcoDiesel doesn't have the active on/off feature.
KC Kevin
KC Kevin
Mission Viejo CA
Truck is headed back to the shop. Same issue. This will be the third time....
KC Kevin
KC Kevin
Mission Viejo CA
Update: The shop couldn't replicate the problem at the last visit about 2 months ago. They did re-program/update the software and changed the fuel filter. Thankfully, I've not had any issues since then.
tcass
Southern Maryland
3.0 V6 Echo-diesel
My 2022 1500 Rebel Echo-diesel with 20100 miles on it has a similar problem of bucking on acceleration. it hasn't stalled and has bucked as many as 5 times in one episode. Most of the time its only once or twice. I took it in and they couldn't duplicate it so they did nothing. Second time i took out the mechanic for a ride and he just said "oh my, that's interesting. They took some throttle body readings and it was -20 so they "relearned" it. it didn't take or i should say it did it again, not as often. Took it back and they replaced the throttle body. i got it back home without incident. the next day, it did it again. Took it back last Thursday 29 May. Still waiting on a diagnosis. They contacted Ram and started a "star" case, whatever that is. between this issue and 3 Uconnect 5 radios and a couple of hands free modules, its been disappointing as i special ordered this vehicle. I've had 96, 2000, 2014 and now a 2022 Ram and this is the first one I've had issues with. If anyone has had similar issues, what was done to resolve it?
