22 warlock audio
montanabound
Maryland
So I recently got a 22 warlock for a pretty good deal with all the incentives. So far I love it so much. I’ve had nothing but problems with pickups over the years, so it’s refreshing to get a great powertrain( V6 ). My only complaint is that it doesn’t have the infotainment buttons behind the steering wheel, yet I can feel the cutouts for them. Is there a way to add them?
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
Yes. You can buy all the parts, but it's actually cheaper to go to a wrecking yard and pick up a steering wheel with audio controls. You don't need a new clock spring for audio controls, but chances are the wheel you get will be a leather wrapped heated wheel, and if you wanted to activate the heated part too, you will need extra parts including a new clock spring.
I just added the heated leather wheel to mine for the audio controls but left the heated part inactive.
stembridge
The Middle South
Pentastar 3.6
Leather wheel with audio controls retrofitted in my '21 Tradesman. The wheel is off a '15 truck, so I had to move the wiring harness from my '21 into it for it to work correctly. I did not mod it for heat, tho. Took me a couple hours total to do the swap (since I had to pull and install twice due to the wiring harness issue).
es
