2500 front brake rotors
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
hey y'all,
does anyone happen to know what the Minimum brake rotor thickness is for a 2017 2500?
The rears are stamped right on the outside, but the fronts are not marked on the outside.
Mine are plenty thick yet, but I'd just l like to know for future reference.
thanks
Rampant
NJ
392 Hemi
hey y'all,
thanks
The book says they should be either stamped or cast into the hub area. They may be on the inside of the hub.
The only real numbers they give are that you should measure and record rotor thickness in 6-12 different points on the contact surface and you should not see more than 0.0059" difference between any two measured points.
MADDOG
Living in a Firepit
6.4L HEMI
You're welcome. Always glad to help a forum member here.
