275 55 20 on rear and 275 60 20 on front for 4x4?
Harry Paratestes
ND
5.7s
i just realized i put the wrong storage tires and wheels on one of my 3rd gens. Its a 4x4 and i accidentally put two 275 60 20 on front and two 275 55 20 on the rear. My back hurts so i dont want to swap them again. Would i do any damage if i drove it to a shop across town (maybe 5 miles) so they can swap them out for the right set of wheels/tires i have. It has the anti spin rear differential if that makes any difference. i figured id be fine as long as i dont put it in 4x4?
Thoughts?
Hagar1
Ontario Canada
2012 Ram 1500
Thoughts?
Just don't use the 4 wheel drive and you should be ok.
Hagar1
Ontario Canada
2012 Ram 1500
Thoughts?
Back in a different life, I once encountered a Ramcharger that came from the factory with a 2.92:1 in the rear and a 2.87:1 in the front. On snow or even wet roads it wasn't noticeable BUT get on to dry pavement and every 3/10 of a kilometer you would swear that you were rear ended by a Transport truck. That was during the bad years in the early 1980s.
Harry Paratestes
Harry Paratestes
ND
5.7s
lol
2 different gear ratios from the factory now thats funny
Harry Paratestes
Harry Paratestes
ND
5.7s
Does the front driveshaft spin even if not in 4x4? Ive never looked into it on these 3rd gens
MrBonez
Central Alabama
2008 Laramie Quad Cab
You'll probrably be OK driving it a short distance (About 5 miles from what you said), it's when you have two different sizes on the same differential/end of the vehicle you may have to worry about it messing things up - And even then it's a matter of how different they are in height to each other as in worn vs new - Height will change (Decrease) as a tire wears and that's only natural.
If the 60's are worn and the 55's are fairly new, that should make them close enough you won't have a problem at all doing that and the fact they aren't that different to start with is good anyway.
THIS.
Since we're talking about different ends of the vehicle with a difference vs the difference being on the same axle set/differential, it's fine to do that.
Hagar1
Ontario Canada
2012 Ram 1500
lol
Chrysler used a 2,92:1 back in that era and I thing GM used a 2.87:1. The axles were made by the same company, Dana, I think. Apparently one, or perhaps more axle assemblies took a trip to the wrong pile. It was interesting alright. The Engineers at Chrysler didn't believe me but changed their tune when the ring an pinion landed on their desk.
Johnnguyen6596
