295/70-17
Jrsdar
Pa
I have a 2018, 1500, Bilstien up front set at max. Bilstien 1” and 2” spacer in rear,
Currently have 285/70-17
Question is, anyone have 295/70-17 on their trucks???
Any issues with clearance or rubbing at wheel lock??
I am using the stock Alloy wheels.
Thanks for any help
heckcat9
UT
The difference in diameter and width between the 285/70 and 295/70 is only about 0.5 inches, should be fine as both hover around a 33x11.5 tire, but ultimately only you know what the clearances on your truck are.
If you want to be sure, jack up one of the front control arms and move the steering from lock to lock while checking the body, fender liner, bumper, and suspension clearance to be sure you have that extra 1/4 inch or so of height and width on each side. :)
Jrsdar
Jrsdar
Pa
Thank you,
I’ll do that
