2WD height question
norton333
I leveled my 2wd with RC coils, love the result and the truck drives fantastic.I then went to a 275/65/20 tire, truck still drives great, my question is would a change in shocks give me just a bit more height? with the larger tires it just looks like there should be a bit more space between the tires and fenders.I'm not looking to do anything drastic, as I said it drives great as is, here is a pic for reference. ZhJTmzL.jpg
DANIEL AYALA
California
Look into bilstein 5100. They are adjustable shocks. Less than $100 per side on Amazon.
Sent from my SM-G975U1 using Tapatalk
BOWERSFJ
Uniontown OH
Can’t answer your question, but dude the black-n-silver with the graphics and the balls to go raised white letters out looks awesome !!! Nicely done ... Wish I could find some 35 x 12.50’s with RWL
norton333
norton333
thanks!
co-pilot
houston,tx
Truck looks great!......I would leave it
I think if you go higher you'll lose ride quality unless you change to a spindle lift.....just my opinion...
norton333
norton333
Thanks, I don't want to do anything drastic, it really does drive great, I was hoping better shocks would give me just a bit more.
Lifted2wd
Toss a rear coil spacer in. I have 2wd lifted 4"/1.75"
norton333
norton333
Thanks, I used the RC level coil because I wanted to avoid spacers, but a rear spacer is a different deal correct? can you be more specific on what this would take? This is a little out of my territory.
norton333
norton333
Bird
Phoenix AZ
I agree it's a bit much for shocks, considering that's what I paid for both sides. I doubt those spacers would have any effect on the front.
norton333
norton333
Thanks Bird, that may be the way I go, the 5100's may be more than I want to spend.
Lifted2wd
I would like this, but is it $99 per shock? that $400 before installation, I did find these rear spacers as Lifted2wd suggested, but won't just raising the rear push my leveled front back down? If not these Maxtrac rear spacers look pretty good.jSNBoTm.jpg
Reach out to CST. They seemed really reasonable. I'm running their lift. Day star has a rear spacer for the 2wd for 129.00 for the pair. You dont lose stock ride quality. Also this will not mess with the front or bring it down
SportyJames
Corpus Christi
2015 RAM 1500 Sport
Agreed. Not a fan of raised letters but on this truck it looks great
norton333
norton333
The maxtrac is only $62 and gives you a 1.5 rear lift as opposed to Day star 1" lift for $129, so I'm leaning towards Maxtrac.
norton333
norton333
I am still debating putting the Maxtrac 1.5 spacer in back or leaving the truck as is. I've read people have clunking noise and movement after adding rear spacers, anyone experience this?
Lifted2wd
I have a 1.75" spacer in the rear and have not experienced any movement or noise. I have towed and had no issues
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
If you increase rear height, I have some Maxtrax rear shocks Id sell cheap. They are their OEM ones that comes in the 4.5"/3" kit, I just swapped them our for Fox 2.0's
