corneileous
- Sep 6, 2016
- 7,139
- 4,143
- Location
- Podunkyville, OK
- 2018 Ram 1500 Limited 4X4
- Hemi 5.7
Yeah, as a matter of fact, I do remember that little discussion but in case you forgot, that was about you and a few others thinking a higher geared truck could run a quicker quarter mile or some ****. I wasn’t about the reason why there’s higher geared trucks and lower geared trucks so I’m not even gonna touch all that other diatribe you just typed.With the 3.21 and the 3.92, combined with the zf 8 speed, there is NO difference on the highway. That, is a fact. Do the math, look at the available gear ratios. We've done this ad nauseam on the other forum because people are coming from their background of 4 and 6 speeds and thinking a 3.92 is still significantly different in our new 8 speeds. It's not. Gear ratio = Gear ratio.
If my truck is pulling in 7th gear on the freeway, my gear ratio = 2.6322
Your truck will be in 8th, your rpms will ~ equal mine, your gear ratio = 2.5088 (diff of 0.1234)
If my truck is pulling in 6th gear on the freeway, my gear ratio = 3.21.
Your truck will be in 7th, your rpms will ~ equal mine, your gear ratio will be 3.2144 (diff of 0.0044)
If my truck is pulling in 5th gear on the freeway, my gear ratio = 4.2051
Your truck will be in 6th, your rpms will ~ equal mine, your gear ratio will be 3.92 (diff of 0.2851)
So to answer your question, yes, the 3.92 CAN pull more. But it's only really relevant immediately off the line, when both trucks are in first gear. Notice how extremely close those 3 gear ratios are too eachother? You will not notice a difference. Similar numbers for 5 out of the 8 gears.
The 8th gear in 3.21 will downshift on a hill sooner, but that's the entire point of the 3.21, give you that extra gear ratio past the 3.92 to keep your rpms lower on the freeway. If you run into a case where lots of hills give you lots of shifts into 7th, just use the gear limiter and now you're in the same gear as the 3.92 in 8th.
No, I haven’t. See, you’re doing it again. Lol. I bought my 3.92 truck because that’s what I wanted. Sure, I am a little bit about gas mileage but, not really. If I was interested in saving gas, I most certainly wouldn’t have got what I got.Have you never driven on the freeway in 8th and thought "gee, these rpms are high and this motor has power to spare, I would love another gear"? I bet you have, well that is what the 8th gear in 3.21 feels like. Of course it will have to downshift sooner, but the upside is that you're saving quite a bit of gas.
I brought it up because a weight-distribution hitch will put more of the tongue’s weight on the trailer reducing it on the hitch.As for the WDH, I really have no idea why you said what you said about it then; the only thing that matters is that his truck will be payload limited, in either gear ratio. He will not be able to pull a travel trailer > 8000 pounds even WITH the 3.92 because he will be past the payload.
But I’m curious- Ram put a max trailer weight of 11,000 on my truck so explain to me why I wouldn’t be able to do that with a WDH and minimal weight in the bed?
