3"drop springs
Elliot_Soapy
Omaha
Has anyone put on 3" rear drop springs and how do they ride? Do you have to relocate anything or change shocks
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
I took a set out of my truck. They rode fine, no issues. Still had stock shocks. They were manufactured by ground force. Still have them in the garage somewhere
baldyloxz
Maryland
3.6 v6
Hey
Thinking of lowering my 2013 1500 but wonder how much of the load capacity is lost and wether the ride characteristics change (softer/stiffer). I seldom haul more than 1000 & guess the shorter spring would handle that. If you have any thoughts I'd appreciate it
Bigskyroadglide
Moderator
Depending on the truck you have you may notice them, you may not. Is your truck a rwd or a 4 wheel drive? Regular, Quad or crew cab?
You will definitely loose some load capacity but you can add air bags inside the coil, helper bags out side the coil spring, etc.
It just depends on what you are trying to accomplish.
For light hauling you will probably be ok, for max towing capacity, it's definitely a non starter.
baldyloxz
Maryland
3.6 v6
It's a 2wd 2013 1500 that I recently got. I won't be hauling much, 1yd mulch, topsoil etc. All very close to 1000 lb. It's a daily driver bit I have mobility issues and would like to drop it 3". That's about the same as cutting out a coil. I'll be buying drop coils tho.
Also wondering about steering & suspension or drive train issues this may cause
Thanks for help
baldyloxz
Maryland
3.6 v6
Sorry, 1500 Tradesman quad cab, short bed & slt trim package
Bigskyroadglide
Moderator
My recommendation would be ground force, maxtracc or crown 3 inch rear drop springs.
They can be purchased separately, easy to install and no other items required unless you want to get deep into the suspension.
You will loose towing and carrying capacity.
You can install without doing track bar relocation and use your normal bumpstops
You do realize a 1,000 lbs is a half ton, which is what the truck is rated at with everything stock. If you install these springs your capacity will be less than the factory rating.
