3 way or 2 way
Rockit
Vero Beach, FL
well getting around to upgrading the sound in my ram . My question is with doing a set of 3 way components so 1" tweets in the sails and 6.5 in the door and 3.5' in the dash stock location passive but would love to try active powered . my budget is 2-3k for everything I will have a single 12" sundown sa12 with 1k powering it in a vented box so just the mid and ho set up . In my last ram I did a set of Rockford t3652 powered by a Hertz 4ch bridged and it was ok but I wand better lol
autokraftgt
Hemi 6.1
3-way is the way to go. With active, you'll have a channel per speaker and make sure your dsp has enough channels as well...each channel (speaker) can be tuned independently.
I personally feel a 3-way is easier to tune than a 2-way....with a 3-way, you won't be asking a speaker (say, midbass) to play frequencies that the speakers is uncomfortable playing...midbass will have a small window of frequencies to play, midrange same deal, tweeters, same deal....all speakers will be comfortable and set up for success so to speak
Rockit
Rockit
Vero Beach, FL
yes it makes sense I was looking at the new Morel Maximo ultra 603's or the Hertz esk 163l.5 not a whole lot of choices for 3 ways thanks for the input
TomT
SoCal/OC
There are tons of 3 way options. If you want to go big, Audiofrog GB series with a kick ass amp will rock. There are also options from JL, Focal, Dynaudio, Sinfoni, Audio Development, and the list goes on.
A quality 6 or 8 channel amp (JL VXi, Zapco, Mmats) would do a good job powering all six channels. The VXi has a built-in DSP and if you get the 8 channel you can bridge two to each midbass.
autokraftgt
Hemi 6.1
Yea I agree with TomT, you have many many options. I could be wrong, but most reputable speaker manufacturers probably have a 3-way component set, OR atleast an advertised mid bass, midrange, and tweeter....maybe not in their entry level selections, but def mid-level options. You can spend a little or a lot. If you're on a budget (like most of us) I wouldn't even look at Sinfoni or Dynaudio's Esotar series....each of their speakers will cost what a nice component set costs from other manufacturers.....but man they sound good lol
Audio Frog is a great option, but I wouldn't call them affordable either....however you won't miss the money spent that's for sure!
Best of luck
Rockit
Rockit
Vero Beach, FL
my best past experience has been a set of Hertz hi energy 6.5 2way comps with a couple hundred watts going to each channel. It sounded good and got loud but I did not have any kind of eq or dsp . Gosh I really need to listen to some of these hi end speaks to see if its worth it or how much better are they , it excites me to know that better sound is possible this is why I am trying to plan this correct as to get the best set up for the cashola. I have an eye on a Zapco 6ch that is on sale as I had their 4ch and mono amp with some kind of special not rca connectors I remember there was zero noise from those amps
Steve58
