35's with bils..tire shop said no!!
swh822
Ok so I called my local wheel shop and inquired about BFG KO2 35x12.50x20 with bils at 2.8 they said no can't do it...
Why not!!!
I was looking at going with a 35 and bils at 2.8 and a 1' TGC spacer In the rear ..?
Any input would be greatly appreciated because I'm driving myself nuts here ..
Truck is a 2015 1500 sport crew cab..
Sent from my SM-G935V using Tapatalk
quietpeen
2021 TRX
Hellcat
They should fit...what are the specs on your wheels?
2014greatwhite
Western mass
I had 35x12.5x20 atturo trail blade xt on my truck with bils at 2.8 and I only had run at full lock on little nub on drivers side wheel liner. They won't fit on stock wheels without spacers.
Ram-engineer
hemi 6.4
Ok so I called my local wheel shop and inquired about BFG 35x12.50x20 with bils at 2.8 they said no can't do it...
Why not!!!
Personally I hate those tires they don't self clean if you get them offraod at all. Depending on what year I have seen 35's on them I run 37x12.5r 20 on my 2016 with a level and that's it. Summer tires for towing are 325/60r 20's. Make sure to get a tire rated for your use or get a summer towing set and a winter set like I did.
Sent from my Pixel XL using Tapatalk
S
swh822
I was either going to keep my stock sport wheels or get the XD rockstar 3
S
swh822
What size spacer would be needed with a stock sport wheel?
Ram-engineer
hemi 6.4
What size spacer would be needed with a stick sport wheel?
Call your local discount tire shop. Or get online and they will tell you what can fit without using a spacer. Spacers are bad and best to just get the correct backspacing on the rim.
S
swh822
I don't do any towing, and the extent of my off roading is the rocky dirt back roads in the country
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I believe most run a 1.5 spacer that is hub centric. Just domt buy cheap ebay ones.
once those are on you should fit those 35s fine as plenty of other people have.
Also from what I have read some 35" bfgs run short, not sure which ones your looking at since you did not post that info but the KM2s from what I have found run close to 34s then 35s so that should give you a little more clearance.
quietpeen
2021 TRX
Hellcat
you would most likely need a 1/4" spacer to run those tires on your stock sport wheels
Captain_X
Did you ask what size tire they would put on? It doesn't count like you have a specific need.
S
swh822
Yes they would be the BFG KO2's
lokal907ryder
wasilla, AK
All that's needed is 1/4" wheel spacers in the front to clear the 12.50 tire on the stock wheel. otherwise it will rub the control arm. every tire measure's different but with stock wheels you should be fine with no rubbing while full lock with that set up and 1/4" spacers. I've done it on many 4th gens with a few diff tire styles.
reddevil78
5.7 he I
Stock sport rims
Bills at 2.1
4"zone lift
Wheel spacers "1.25"
Tires are 35x12.50r20 Toyo M/T
2014 ram 1500 sport
Bam!!
Ram Outdoorsman
I'm running a 35/12.5 on stock sport rims without spacers with bils set at 2.8. I only rub at full lock in reverse. Sorry she is a little dirty.
Ram Outdoorsman
Older pic but she is clean
Ram Outdoorsman
They do a bit but not alot. You can see like the first set of tread. They give the truck a nice aggressive stance without being out to far. I'll snap a pic real quick so you can get an idea.
dterrel
