37x13.50r17 Toyo m/t tires
olyelr
Kewadin MI
Looks good fred!
But…there is no way that has a 6” lift. It would be ridiculously skying 37’s if it did.
62Blazer
Midwest
I put Toyo 37x13.50r17 m/t tires on my 2015 2500 6.4 power wagon and it has a 4” lift and a 2” leveling kit but had to grand the ends off the bottom of the weel well and no rubbing on suspension as I was told it mite do ….View attachment 521319
Looks good, but agree about the lift. This is mine with 37x13.50R17 tires and only a 1.5" Thuren lift on the front and 1" spacers on the rear.
olyelr
Kewadin MI
Yea but our trucks come from the factory with a 3” lift mine is only 1:12 more
1.5” up to ‘18…’19+ have closer to 2”.
So yea…that looks more like 1.5” lift with 37’s to me. I was gonna say, a 6” lift on a power wagon is ridiculous.
62Blazer
Midwest
As already posted, a '15 or '16 PW (the OP and mine shown above) are about 1.5" higher than a regular Ram 2500. Mine is lifted 1.5" higher in addition to the factory 1.5" lift, so around 3" total lift over a regular 2500. The point to the replies is that the truck in the OP definitely does not appear to be anywhere close to a 6" lift over a stock PW (which would be almost 8" of lift on a regular 2500), and not even a 6" lift compared to a regular 2500.
On mine, again with 1.5" Thuren springs over a stock PW, and 37x13.50's required a decent amount of trimming on the front to clear when turning. That is also with rims with far from optimum backspacing for clearance.
Maligator
Hem 5.7
What offset wheel you running bc my 37x13.5 Coopers rub like a SOB on my sway bar with a +18mm wheel
62Blazer
Midwest
Mine are -6 offset which is the only option for the Pro Comp 069 style wheels (and fairly common for a lot of 17x9 wheels). Definitely don't rub on the swaybar, axle, or frame but they rubbed pretty bad on the lower backside of the front fender openings when turning.
