4.56 ring & pinion
sewardmark
Minnesota
Just installed new ring &pinion, went from 3.73 to 4.56, I have 35"x18 tires &wheels, on a Ram2500HD 5.7 Heml, WOW With the tune from Hemifever and all the bolt ons. This truck is a BEAST, FOR you guys runing big tires &wheels with high gears, try a gear SWAP, loving truck all over again, even though it only has 4000 miles,
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Questions for you.
I have 3.55 and personally hate them. Usually I have 3.92 factory but I feel upgrading to 3.92 or even 4.10's will work for me.
Did you do this install yourself?
Any pictures at all? If not I understand.. it's easy to jump into something and just wanna get it done.
If you didn't do it yourself where did you go and how much?
Also is your truck a 4x4? If so how bad was the front diff?
Thanks.
S
sewardmark
Minnesota
I had the work done at clutch &ujoint in Maplegrove Mn, its a 4x4
And the cost was 2300, they said that the front axle was Noproblem, nobody else in Mn wound touch the truck said it would be to difficult, WRONG, I know it was expensive but worth every penny, sorry no pictures can't figure out how to download on here
Razzaa
How did they make a carrier for the front diff? I thought it was only possible by replacing the whole assembly with a used one?
S
sewardmark
Minnesota
Yes no new carrier, everything went with out a problem, I was afraid to do the job myself, because everyone said in mn it was alot of extra work, talked to randys ring &pinion said it wasn't a problem at all, dealer mckays dodge in st.cloud mn quoted me 8000 bucks, told them that was the last vehicle I or anyone I know would buy from that hole! !!! Do not let the week shops tell you it costs alot,
Arctic-Rodz
RGV, TX
6.7L Cummins
ive always said a gear swap is a great upgrade to bigger/heavier wheels and tires.
glad you liked it
1882
My local guy is quoting me $1800, now I just need to get the parts. Dealer quoted $2300
blkcountry426
hemi blown 426
where did you find your 4.56 gears for the rear end at
1882
Doesn't Moe's sell everything you would need?
S
sewardmark
Minnesota
Moe's can't get 4.56 out of stock and backordered. A am stopped production
glsander
