4.7l exhaust question
DDean
Currently running flowmaster 40 SI/DO. Would like to get a deeper more aggressive sound. Recommendation? Pipe size?
DDean
DDean
Hope i dont get in trouble for bumping.
Ram4.7L
Central NJ
I have a cherry bomb glasspack on mine, with stock pipe and its real aggressive
DDean
DDean
No exhaust shop here will mess with cherry bombs
SilRam1500
South Florida
I have the same set up as you and wanted a more aggressive sound so i removed my catalytic converter. Has that real nice rumble.
DDean
DDean
Dont have the tools or a garage.
wickedares
4.7 v8
Do you have a vid of your trucks exhaust? which cherry bomb glasspack did you put on
wickedares
4.7 v8
what did this do to your 02 sensors was there one before and after the Cataletic converter?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Sometimes they'll trip, the 3rd gens are more likely to, actually.
You install a spark plug non-fouler on the rear O2 sensor so it doesn't get the full whiff of exhaust.
wickedares
4.7 v8
im a little ignorant to a spark plug non fouler i searched it on google looks like it goes on the sparkplug itself but your saying you put it on the O2 sensor. and that does what? make it not throw up a Check engine light? or does it help it regulate how much fuel it needs to be injecting.
and what do you mean by "sometimes they'll trip"
sorry for my ignorance im still trying to research how i want my exhaust setup and see what all my options are. and what impact they have on the performance or if i could expect a Check engine light from one way or another.
JPT
NY
2015 Big Horn
Look at this link with pictures:
$5 o2 cheater/non fouler how-to - evolutionm.net
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
dis guy got ya fixed up ^^
JPT
NY
2015 Big Horn
thank you for linking that!. so according to that if my truck has one before and after the CC than i would only need to add that modified spark non faouler to the one after the CC.
Correct. The "downstream" O2 sensor is looking for a difference in exhaust. It is checking to see if the CC is working. It looks for a difference in voltage from the before and after O2 sensors.
wickedares
4.7 v8
but you were saying sometimes they trip, and by that you mean the CEL comes on, but doesn't necessarily mean you're going to get worse gas milage?
and if the CEL decides to trip can you just run to autozone or somewhere to take it off and hope it doesn't happen again?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Yes. If the PCM is persnickity, it will pop on the CEL and a P0420 (catalyst inefficency) code. Some trucks do, some don't. The 3rd gen trucks I know are more picky about it than the 2nd gens like mine. You won't necessary lose mileage as the Dodges don't use the rear O2 sensors to as high a degree but you DO have a newer truck, so that might be different.
You can reset it, just make sure you don't have emissions testing in your area because it will fail. lol
wickedares
4.7 v8
Luckily we don't have emissions test around here. people run straight pipes and such all the time.
but the CC being removed appeals to me to get a consistent tubing shape all the way through the exhaust to maximize the tone.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Could always go with a high flow cat. The huge restriction is the factory y-pipes on these trucks, not so much the cats.
alphaprojects
