4.7l magnum compatibility
judge_cary
Blue Eye, AR
4.7 Magnum
I have a 2003 Dodge ram 1500 that has a bad 4.7l magnum in it. I found a 2008 Dodge Durango with low miles but no title for a price I can't beat and I was wondering if the 4.7 will work with my 03'? I haven't been able to find much info on this other than in 2002 they changed from 16 tooth to 32 tooth gears on the cam.
Sent from my ONEPLUS A6003 using Tapatalk
HemiLonestar
Navy Badge Coast Guard
MD
No. Too many differences between your 03 and that 08 (engine was redesigned in 08 with revised cylinder heads w/dual plug ignition, different cams and upgraded intake manifold w/fly by wire). On top of that, it does have a different tooth count crank wheel. The tooth count you referenced is for the crank gear, not the cam gears.
