After doing a lot of research and deciding what type of lift to go with, I have decided to go with a BDS suspension lift kit. Where I am stuck is deciding between a 4" or 6" lift. Reason being is I've heard lifting a truck there's only so far you can lift it before you start getting your steering at weird angles that it shouldnt be and causing strain and issues.
With that being said, my question is if I go with a 6" lift would there be any issues with my steering or would I be ok and not need to extended the steering?
