4 wheel drive issues
rrrruss
4.7 8L
My truck got stuck in about 5 inches of snow... The 4 wheel drive didn't feel engaged and there was a clicking noise like a pencil in a fan blade... Rotated tires today and put the truck in 4wheel drive... Should the front wheels spin when up in 4wd??...
bhonshell37
Washington
Yes, one of the front wheels should rotate in four high or four low. All four will rotate if you have front and rear lockers
Sent from my SM-T550 using Tapatalk
R
rrrruss
4.7 8L
thanks for the reply......both rotated, front wheels...very easily.
bhonshell37
Washington
With the fronts turning in the snow, I would venture to say the tires could not get traction due to tire type or tread depth or no traction to be had
R
rrrruss
4.7 8L
Thanks for response.. The clicking noise just sounded off-bad-not right as the tires spin.
bhonshell37
Washington
Check your axel boots for tears. Could be that the grease is contaminated with foreign matter and causing sound your hear.
Sent from my SM-N910V using Tapatalk
