HK1837
Does anyone know off the top of their heads if a 2021 Classic would have + or 0V switched headlights?
I just want to fit a temporary front number plate LED light bar, one of these sorts of things:
www.narva.com.au
Will only be a temporary fit until I sort out some projector headlamps.
WIll drive it via small relay, just want to know if the factory high beams are +12 or 0V switched so I can connect the right side of the relay coil to ? My Toyota has 12V to the high beams all the time and the 0V is switched. From what I can make out off a few diagrams online it looks like the Ram might be +12V volt switched headlamps.
Narva | Explora LED Light Bar 14" INCH Single Row and LP Bracket
9-32 Volt 5 Watt L.E.D Light Bar - Narva's new Explora ultra slimline L.E.D driving light barfeatures 'Advanced Optic Drive Technology'. The light output from the 12 x 5W high powered L.E.D'sis captured and focused to produce a more penetrating light output down the road. The result is a30%...
www.narva.com.au
