4th gen ram hemi avoid?
gofish101
2018 Outdoorsman CC
Would they be able to tell if you installed one and took it off for work, wouldn't think it would leave a footprint.
I don't believe they would know but I also take it there for oil changes and sometimes just drop by to ask a question. I like the idea of it being a factory thing like other manufacturers have.
OCDTech
Louisiana
Yea dont know why they don’t incorporate this
88ROOK
illinois
it doesnt leave a footprint, its just plugged into the pedal, its more of like voltage spike to the TB. before i got a tune i had it in to the dealer a couple times and they didnt say a thing. now when i had it in the other day he did notice the headers and said "you realize if something happens to the motor i might not be able to help you out"
indept
South Jersey
The best V-8 motor I thought I had owned previously was the Chevy 5.7 350 vortec in my 98 suburban. Smooth, easy to work on, reliable, and lasted well over 200k (still going after I sold it to my brother in law). The V8 Hemi is better in my opinion. Great horsepower and torque, smooth, great power curve, really good mileage/fuel efficiency for a big motor and when paired with the ZF8 tranny I really don't think there's a better combo especially since you can add 100 HP and still have a reliable engine. Yes, it has an Achilles heel with the single cam and relatively older pushrod design but man, it really is a great motor. If you get too worried about the cam/lifters, it's actually a VERY easy motor to work on also and over a weekend you can put in higher quality parts to make it more reliable. I have a ton of friends who have dealt with crappy Chevy/GM and Ford motors with (subjective opinion here) more key problems than the hemis. On the downside the Hemi is more expensive to buy parts for due to quantities, but heck, I still love the motor.
I wouldn't go as far as to call it VERY easy. The fact that you need to pull both heads adds a lot of work to replacing the cam / lifters for a pushrod engine.
JayLeonard
6.7 L Cummins
Yes but then there a good excuse for "freshening" up the heads.
James OBrien
St. Louis
5.7 Hermi
Yeah, good point... It's a pain in the ass actually, when most designs let you pop them through the head/valve train. At least the head gaskets don't go out all the time and you can actually get at everything. At least I can with the seemingly endless assortment of swivel sockets/extensions/ratchets/wrenches.
Leonard Russo
Rhode Island
My 6.4 in my 2018 is whisper quiet even at startup in the morning. Especially compared to my buddies 2017 5.0 F-150 . That thing is a rattle box .
tron67j
Maryland
I am on my third ram since 1994. I have had a good run with them all and do the normal maintenance with them. I think it's like any vehicle you buy, you can have a problem because mechanical things can possibly break. If there is a concern, just buy one of the good auto warranties and keep that in place. Or, put that money aside and keep adding to it and if you ever have an engine problem you've got your cash ready to pay for it.
jmd4100
US
My 2009 hemi crewcab Rambox went till around 325,000 . The MDS went out so while in there they replaced the cam and lifters under warranty
sold the truck with 422,150
Original power train
WOAH
God bless you man! That's awesome!
Sent from my SM-N975U1 using Tapatalk
Hemi395
Cape Cod MA
Wow!! What was your maintenance schedule/oil used??
scott lass 18
rocklin ca
2010 ram 1500
The issue is you only hear posts about lifter failures because people only post things about lifter failures. No one wakes up in the morning and starts a post about how their truck doesnt have lifter failure. If you think about how many rams leave the assy line and compare that number to cam/lifter failures, it's a fraction smaller than anything. Yes it does happen but the likelihood of it occurring to your truck is minimal. I have an 07 with mds it has 138k miles and it goes in and out of 4 cylinders like it did when it was new and I have never had a failure. They're great engines. If you can buy one with about 60-70k miles and it doesnt tick, it most likely wont. The tick usually starts when it's relatively new
wow very lucky 27 percent bad now ! 2011 worse mine bad bet 2010 59,300 not right !
scott lass 18
rocklin ca
2010 ram 1500
I have come to realize, ( very paranoid as are you ) that the more research you do the more "bugs" you will find. I once researched manual tranny oil on the Subaru Forester forum for so long until i decided whatever is in my 100,000 mile tranny now, will just be fine forever.
Few topics i tend to avoid: oil filter, mpg, trans oil, mds. Now i say that with a little humor, i do of course look into those sometimes, but what i mean is you will run yourself into the ground to make a decision sometimes. So much back and forth, thats BS, no way i will get that mileage, used that super duper top teir oil, my motor blew up the next day, kind of talk.
In the end, make the best decision you can with some research and in the end it boils down to the odds of it happening to you. All vehicle manufacturers have turds, some more than others. One big one with engine oil i don't go by is the Oil change monitor, i like to change between 5 and 7K miles, Not saying there isnt oils that can't go that long, i just accept the money it costs to do it earlier. Why go up right to the line of when the oil loses its protection, just cut it a little sooner and i don't have to worry as much.
Like others have said, i see more easily as many rams in my town now than anything else. Which is a lot more than i used to, there climbing the ladder in popularity for a reason, if there were that many failures, you would probably hear a lot more about it than you do.
Thing about it is, by the time we realize how amazing some vehicles are, ( how long they last almost problem free) its too late, they all have a ton of miles on them.
If we knew how good the mid 80s Toyota 4x4 were most of us would have bought one of those,like them or not i would have. Or many years of the Chevys 90s to the 20010 or so, almost indestructible.
So, i've trained myself, not to stress so much, do the research you can, talk to others on here and i'm sure you will make a decision your eventually happy with.
PS, the Ram was the first vehicle i've ever bought purely on impulse, I did, NO research on it.
chat with local machinic chevy guess what lots of trucks msd same problems sad right they companys now buy the cheep parts this is why !
scott lass 18
rocklin ca
2010 ram 1500
Anengineer, if it helps, according to some on various forums, the lifter failure issue has been corrected for model year 2016 and up. No idea if this is true or not.
wow sure hope so sadly mine has the death code going on and load ticking now crying in my wisky now hope shop comes threw and replace engine right now there cant get the lifters back order over a mouth so kinda screwed how long it well take ! here dealers have autos sitting over a month now !!!!
scott lass 18
rocklin ca
2010 ram 1500
so what warrinty u had on power train like 100,00 they just replace parts right ?
E-DAWG
Ontario, CANADA
5.7L
It takes me forever to find a newer vehicle. Every one I have owned I have been plagued by paranoia about there being a fatal flaw with the motor. When I bought my 3rd gen I scoured the internet for posts about the valve springs breaking on the early hemis and dropping the valve into the cylinder which mine has never done for the 5 years I have owned it. I'm just trying to get a feel for the risk or which particular years seemed to have a higher failure rate. It seems like 2011 was the worst year for some reason. I used to work in a repair shop so I am pretty mechanically inclined and can find problems on used vehicles, I'm just worried about something developing after I put 20k miles on it.
Buying anything used carries that risk. Used is always a gamble. Unless you have x-ray goggles. Crap Shoot on many used cars
tcburch
Agree with everything you said...I've been guilty of over studying a problem and missing out opportunities. However, I did NOT miss out on the mid 80s Toyota...while I just purchased a new 2019 Longhorn (second) 1984FJ60 (very low miles at just over 100K) that I bought new in Dec. of 1983. Haven't had a major problem in the 37 years I've had it, and as I like to say to everyone I meet, it has never failed to get me back from anywhere I've taken it (live in Colorado btw)...point being, I love them both and take of them...change the oil, change the oil, drive them and enjoy them...PS the FJ60 is on the block...age is dictating that I get rid of my toys with manuals (hips, knees, right shoulder, etc.)...hate to do it, it's "family"...LOL...
Old Cop 66
75 K, not one problem. Never.
Solid truck, would not hesitate to buy another, other than like all major brands, price out a new one, can give you cardiac arrest.
Drives real nice without dragging a payment book!
No members online now.
Steve58
