4wd Low problem
95Twenty500
95 dodge 2500 single cab long bed 4wd 5spd
5.9l v8
I just bought a 95 2500 4x4 dodge about 2 months ago and when I bought it I tested the 4wd high but not low. High works great but low I am confused on. I have been searching a lot and seems most people can't even get into 4wd low but I can pull it into 4wd low and the 4wd light comes on but when trying to drive It won't move anywhere. Also I have the nv4500 trans and 241 dld transfercase. So its in 4wd low but when I put the trans in any gear and let out the clutch it doesn't move anywhere its like I'm in neutral.
I havn't found anyone with this problem, so I was wondering if anyone had any advice, any is greatly appreciated.
firefighter
I'm having the sane problem in my 99 1500 if anyone can help could ypu send the info my way
Cthulhu
Calgary, AB
Cummins 5.9
Are you stopping and putting the truck in N before going into 4low?
Sent from my Z10 using Tapatalk 2
leadrofthepak
Shelton, CT
Have you checked to make sure there is sufficient fluid in the transfer case (and that the fluid does not smell burnt or have metal flake in it)?
Merc225hp
NA
truck
gas
I would test the 4wd shift linkage under the truck. Set the E brake, block the tires, put the tranny into N, shift the xcase into 4L get under the truck (not running). Disconnect the shift linkage or loosen off the adjuster, then see if you can move the lever on the xcase (up behind the cardan joint on the xcase)further into 4L. If you can't find 4L then rebuild time it is.
There are rebuild kits on the web, these are not hard xcases to service, just download the fsm and follow it.
The light on the dash is controlled by the CAD on the front diff, the CAD is operated by a vac switch on top of the xcase when you shift it into 4H or 4L, at least you know that works.
Can you post up the numbers on the red tag thats should be on the xcase.
firefighter
Ok on mine the 4L is just free spinning while its in gear so do I just need to rebuild it right.
DJack
