5.2l engine stalled out while driving
rrb6699
Orlando FL
I can't believe it may be the crank position sensor again! what could be causing that sensor to go. what tools can you use to get to the 2 bolts on it?
from underneath you can see it but not reach it. from top you can reach but cannot see it.
I'd hate to buy a 90.00 or more sensor and have it blow.
but symptoms point to this being the problem. no spark but cranks fine.
UPDATE:
installed a new (cheap chinese) cps today and truck cranked right up!
I don't consider the problem solved though.
I still want to figure out why this is the 4th CPS I've had to put in this truck. before you say. the last one was a Mopar.
any ideas appreciated.
rr
RodeoRam
Supporting Member Air Force
North Carolina
Hemi 5.7 2500 CC
I had both crank and cam position sensors replaced a few years ago on my 2001 5.9L. The mechanic said that when one sensor goes, it causes the other sensor to go out, too. Now, I don't know if that is really true or not, but it might be a place to start. Have you replaced the cam sensor?
rrb6699
rrb6699
Orlando FL
no but maybe if the cam sensor goes the crank cps will follow but not the other way around. I don't know.
I decided to replace the pcv valve and see what that does but it hasn't arrived yet.
one odd thing happened is when I cleaned out the breather with brakleen and nudge torqued the plenum bolts after I replaced the Map sensor. I got over 20mpg on a 160mi round trip.
I thought back to make sure it wasn't a mistake somehow but I think it was legit!
I'm gonna see what happens after next fill up. more city driving this time.
