5.9 starting
12vcummins59
Cummins 5.9
I have to give my 96 12v a little bit of throttle every time I start it or it will crank for a while before it starts. When it's warm I just have to tap the throttle while I turn the key and it will start and idle fine. If it's cold I have to keep a little bit of throttle for a while or else it will die. The colder it is the longer I have to keep throttle. I'm thinking I just need to turn up the idle. Any suggestions? Thanks
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Check for fuel pressure. Usually hard starts like that are due to worn lift or injection pumps.
12vcummins59
Cummins 5.9
Thank-you that was my next guess hopefully not the injection pump... next thing to be replaced is the lift pump
dudeman2009
Magnum 360
Check for fuel pressure first. If its low, then replace it, but it its reading properly, why waste 200-300$ on a part that isn't bad.
12vcummins59
Cummins 5.9
I actually did try to replace the lift pump a couple weeks ago because I'm pretty sure the old one is bad, it's got that clicking noise coming from it plus the way it starts and the p7100 injection pumps aren't really know to go bad very often at all, ended up putting the old one back in because I made the mistake of ordering a cheap lift pump from Amazon that ended up not working, but I do agree with checking the pressure I just need to get a gauge
