5 speed snafu
02blueram76
Hello i am doing a 5 speed swap in my 1999 1500 my truck has the 360 the trans and engine wiring harness is out of a 318 truck. Now i got problems. when we it all swapped over and tried to start it everything lit up and worked as normal but would not crank over and fuel pump wouldnt turn on (i imagine something to do with the clutch pedal safety switch) no big deal so we were probing around at the ignition wires on the column the yellow wire when gounded it would crank over and fuel pump would turn on we got it to fire but somewhere along the line it shorted and blew the 20amp power outlet fuse we replaced that but still nothing the it wont crank over no fuel pump no whipers no radio no idiot lights but the speedo and the rest of the lights still light up before this all happend the odometer said "no bus" but now it didnt say that either. nothing im sure theres other things that dont work also but im really need this thing back on the road soon any help is greatly apreciated thanks
Dodge guy
Brain
Check to see if the computer module from the 318 will fire it up that's what I would do
Lemniscate_Mike
