545 hard downshift
scHemi
2009 RAM SLT Crew
Guys I have a 1500 and when I come to a stop sometimes my Trans will bang into the lower gear while I am applying brakes to slow for a red light. Any thoughts on how to prevent or fix this
savage_46
Alaska
6.4 swapped
First thing first, check Trans fluid level & condition. The cooler lines on the early 4th gens liked to leak. Check the fittings that are near the front right side frame.
S
scHemi
2009 RAM SLT Crew
I'll check the fluid level tomorrow. I chanced the fluid about 25k miles ago.
savage_46
Alaska
6.4 swapped
Be sure to check the fluid while in neutral with parking brake on. Neutral uses the Trans cooler & gives the most accurate reading. Fluid does not flow through the cooler in park.
S
scHemi
2009 RAM SLT Crew
Ok checked the fluid. Seemed to be a quart low. Now I have no idea how that happened. Unless I didn't fill it enough when I changed it. Going to take a look at the cooler lines this week
Sent from skynet
