lchron36
- Jan 25, 2016
- 15
- 4
- 2010
- Ram 2500 ST 5.7
I threw a check engine light, checked the code on the truck. The code I got was p0933, transmission hydraulic low pressure sensor. Truck was driving fine still. So I took it to the dealer, typically I do everything myself, but I was on a time crunch and am driving 1600 miles over the next few days. I was hoping for just a faulty sensor and the dealer would replace it right away before my trip. After running diagnostics, the dealer says I am only getting 25 psi, which isn't anywhere near the 125 psi that should be put out by the transmission pump. The dealer says I need a new remaned transmission and quote me $6500. I obviously wont let the dealer do that work due to the cost. I can pull and replace the tranny myself on a weekend.
So my question is, for anyone who has ever replaced the 545rfe, was there a specific brand or company you went with? And if so how has the transmission been so far? I was hoping there is a big name company out there who has the 545rfe. I know ATS has a remaned one for right around $2000. I have heard both good and bad about ATS in the diesel world, but don't know how their gas trans are. Any other companies, or just general remanufactured trans suppliers I should check out?
Little info about my truck.
2010 Dodge Ram 2500 ST
4x4 Reg cab 5.7L 545RFE
just under 100,000 miles on it
always overly maintained. Trans fluid and both filters changed at 50000 miles
I do tow up to 9k, but not too often. Typically I am loading the bed to payload capacity.
Anyone else have experience with the P0933 code before? Wasn't sure if its possible that the sump filter came out of place and that would cause the pressure loss all of a sudden.
Thanks for your time guys
